Yer M/S price are not the best
Glav or zinc is more pricey than 304 in some places.
But 316 is expensive.
I used 304 RHS to build gates as MS plus hot dip was more expensive. 304 n powdered coated
Trump vs north Korea? your gate priceless. Humans used to live in these dwellings. As you can tell by the flattened house behind this gate! History lesson!
On 5/4/2017 at 6:13 PM, TiTAN said:
If you like the size of the 4 and don't want a bigger phone you can go the iPhone se
On 5/4/2017 at 6:20 PM, TiTAN said:
Ditching the se at this point would be silly on their part considering how well it sells/sold globally. They support the phones for 3-4 years after initial release.
On 5/4/2017 at 7:28 PM, Manne said:
They've made it a prepaid phone now. Locked to Telstra.
the guy at telstra shop told me yesterday they came back 2 weeks ago available on plans and not only pre-paid.
grabbed one for the missus last night :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
