Yer M/S price are not the best
Glav or zinc is more pricey than 304 in some places.
But 316 is expensive.
I used 304 RHS to build gates as MS plus hot dip was more expensive. 304 n powdered coated
Trump vs north Korea? your gate priceless. Humans used to live in these dwellings. As you can tell by the flattened house behind this gate! History lesson!
On 5/4/2017 at 6:13 PM, TiTAN said:
If you like the size of the 4 and don't want a bigger phone you can go the iPhone se
On 5/4/2017 at 6:20 PM, TiTAN said:
Ditching the se at this point would be silly on their part considering how well it sells/sold globally. They support the phones for 3-4 years after initial release.
On 5/4/2017 at 7:28 PM, Manne said:
They've made it a prepaid phone now. Locked to Telstra.
the guy at telstra shop told me yesterday they came back 2 weeks ago available on plans and not only pre-paid.
grabbed one for the missus last night :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
