23 minutes ago, Beyond Blue R33 said:
Has anyone seen the rising Sunday event at barbagello on the 4th? Or been to one before?
Cars n Coffee is this sunday at Kwinana... are they both on the same day?
i went to the first Rising Sunday. heaps of cars got stickered. was a good day but
Clearly you just don't appreciate how rare the Hyundai getz gtr is. It's a 1/1 worldwide. Will be highly collectable in the future.
If your not into collectable cars and like the getz tuner scene then this beast is for you! images%20(1).jpg
Never seen a bad boy like this before? It matches my swimming clothes!car-modification-fail-turbo.jpg.4c1bea07c03e73c563efd30492134a4a.jpg
Hey Trev I was looking up lifter issues on Sau and it had your posts solving the issue?! (r&d maniac) I've noticed a slight rattle in the exhaust cam p/s on no.6. I disconnected the coil pack at rattle revs. 2800-3200 and the rattle went away, phew no piston slap or gudgeon pin issues etc. Was wondering the fix for this without bagging my mate dave out.? Doesn't affect the performance at all and I's only in the specific rev range with the H.t. Lead disconnected? I changed the oil on Saturday and it runs sweet except for the noisey lifter on 6? At those r p.m.?
Hey Trev I was looking up lifter issues on Sau and it had your posts solving the issue?! (r&d maniac) I've noticed a slight rattle in the exhaust cam p/s on no.6. I disconnected the coil pack at rattle revs. 2800-3200 and the rattle went away, phew no piston slap or gudgeon pin issues etc. Was wondering the fix for this without bagging my mate dave out.? Doesn't affect the performance at all and I's only in the specific low rev range with the H.t. Lead disconnected it disappeared. I changed the oil on Saturday and it runs sweet except for the noisey lifter on 6? At those r p.m.?
I ran it hard on Saturday morning early on the old oil and it was noticeable at idle. Only noticeable at the 2800-3200 after the oil change? Would assume it only needs a new lifter? or clean (doubt it) and gapping not valve stem seal honing etc? Any advice?
Can only pick up the rattle in 2nd gear under mild acceleration?
i stripped and cleaned my lifters when i rebuilt the engine because i had a rattle for over 100,000Kms.
ended up getting a different head and modified it and used the lifters that came from the new head. the rattle is still there but turned out to be an injector which doesnt affect performance so i havent replaced it yet but i might in the near future as im considering an injector upgrade to top feeds
  • Like 1
how loud is it?
not sure if you can use an oil flush to get the gunk out... they arent too bad to clean apart from having to get them out. there are also a couple different varieties on our engines. look the same externally but different sizing internally
  • Like 1
sorry too hard to guess without looking.
id imagine with more revs the oil pressure would prevent lifter noise so idle would be worse but thats purely an edumacated guess.
  • Like 1
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
