Finally got to installing the CD player my sister got me for Christmas into the boat, and the fkn power cable is missing from the box FML
If i get up early and get stuck into it I'll have it finished by oh no cable. Wait for the shops to open. F### it.
Yeh pretty much. I'm building a shelving rack in the caravan now. Have to go into town at lunchtime for a pissup so I'll try get one then and wire it up tomorrow
  • Like 1
How did u go with the van shelves? Fitting the marine stereo after the piss up? Just like having sea legs? Nothing like a bit of swell in the garage on the trailer!
Ran her hard today at 18 psi, it loved the 200cell 4x6 metal substrate oval cat. Gained about 1" clearance though slotting the front mounting bracket and adjusting all the hangers to remove tension. All pipe work swaged re-re modified and redone with t-bolt clamps and beyond Blue silicone hoses. Genuine Nissan fan and dayco coupling. Pressed a slight flat into the exhaust to clear the rear sub frame and hicas delete. Houston were waiting for the next problem. You are the weekest link goodbye
Just got home so I'll wire up the stereo first thing in the morning
Only have this pic ATM with the new shelf not completed on the left. Also cut out shelves to go in the robe to convert it to a pantry cupboard. I'll update progress pics
  • Like 1
This place looks amazing. Great view too. Good work Collin.
Yummo! I cooked a beef brisket red wine pot roast for lunch. Every Sunday night the wife and I marinate some fillet steak sit down and watch a movie with cheese platter, meat platter, dips, antipasto, toasty bits and crackers.
  • Like 1
Coolness "how to customise stock stuff way better and faster" a novel by trevs.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
