Finally got to installing the CD player my sister got me for Christmas into the boat, and the fkn power cable is missing from the box FML
If i get up early and get stuck into it I'll have it finished by oh no cable. Wait for the shops to open. F### it.
Yeh pretty much. I'm building a shelving rack in the caravan now. Have to go into town at lunchtime for a pissup so I'll try get one then and wire it up tomorrow
  • Like 1
How did u go with the van shelves? Fitting the marine stereo after the piss up? Just like having sea legs? Nothing like a bit of swell in the garage on the trailer!
Ran her hard today at 18 psi, it loved the 200cell 4x6 metal substrate oval cat. Gained about 1" clearance though slotting the front mounting bracket and adjusting all the hangers to remove tension. All pipe work swaged re-re modified and redone with t-bolt clamps and beyond Blue silicone hoses. Genuine Nissan fan and dayco coupling. Pressed a slight flat into the exhaust to clear the rear sub frame and hicas delete. Houston were waiting for the next problem. You are the weekest link goodbye
Just got home so I'll wire up the stereo first thing in the morning
Only have this pic ATM with the new shelf not completed on the left. Also cut out shelves to go in the robe to convert it to a pantry cupboard. I'll update progress pics
  • Like 1
This place looks amazing. Great view too. Good work Collin.
Yummo! I cooked a beef brisket red wine pot roast for lunch. Every Sunday night the wife and I marinate some fillet steak sit down and watch a movie with cheese platter, meat platter, dips, antipasto, toasty bits and crackers.
  • Like 1
Coolness "how to customise stock stuff way better and faster" a novel by trevs.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
