Scored a new t.v. Today the 65" hd Sony bravia died after 16 months? Had 5yr warranty went up to 4k LG wow. Amazing
Dirt 4 and teken7 with the kids tonight on ps4. Took the Nissan out after work. We're running hard and solid again. Was someone keen for a cruise?
I joined this forum under the impression that you lot like to go out with your cars to enjoy them. Oh how wrong was I now that being said what is it that you lot fear the most. A paint chip or someone else enjoying your car after they pry it out of your cold dead hands. Ffs let's get real we have nice cars but don't want to have fun with them or put kms on them. Go Join the vintage club and dust collection. This is what really f**ks me off people having nice cars who refuse to use them what they were intended for.
So this Sunday?
Not great but can't complain, it's picking up. Issue we find is that during the week it's pretty dead, especially lunch, dinner we get a few but still low numbers but weekends are decent. Hoping weekdays picks up though!
Next time you are up this way do drop by!
We 98% sure we going back tomorrow for lunch. Got a dentist appointment.
This time that octopus won't be teasing me ill get it as a main.
[emoji223]
When's them scallops gona hit the menu ?
Wont mind to try [emoji12]
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
