Scored a new t.v. Today the 65" hd Sony bravia died after 16 months? Had 5yr warranty went up to 4k LG wow. Amazing
Dirt 4 and teken7 with the kids tonight on ps4. Took the Nissan out after work. We're running hard and solid again. Was someone keen for a cruise?
I joined this forum under the impression that you lot like to go out with your cars to enjoy them. Oh how wrong was I now that being said what is it that you lot fear the most. A paint chip or someone else enjoying your car after they pry it out of your cold dead hands. Ffs let's get real we have nice cars but don't want to have fun with them or put kms on them. Go Join the vintage club and dust collection. This is what really f**ks me off people having nice cars who refuse to use them what they were intended for.
So this Sunday?
Not great but can't complain, it's picking up. Issue we find is that during the week it's pretty dead, especially lunch, dinner we get a few but still low numbers but weekends are decent. Hoping weekdays picks up though!
Next time you are up this way do drop by!
We 98% sure we going back tomorrow for lunch. Got a dentist appointment.
This time that octopus won't be teasing me ill get it as a main.
[emoji223]
When's them scallops gona hit the menu ?
Wont mind to try [emoji12]
  • Like 2
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
