Lots to be done to get it going?
I removed the alarm because the central locking wasn't working. For now I've wired it up without one as wasn't that happy with only one available local.
Wire up wideband
Charge n fit battery
Do skids
So no not very much
  • Like 3
Yeah shoulder getting sore again, neck is just starting to get sore but could be cause not takin any meds today (trying to gauge the pain as they have given me really strong meds)
Some meds before bed time zzz.zzz.zookey!
Doc gave me tramadol last time I done the discs in the lower back. Was insane. Couldn't tell if I was awake or asleep? Took them for 4 days then jumped off them quick. Nasty as. Night terrors and sweating like a maniac. Scary.
Be careful of doctor trevs! Will be recommending more beers as a suitable treatment plan:-)
200mg morphine, very full on lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
