Lots to be done to get it going?
I removed the alarm because the central locking wasn't working. For now I've wired it up without one as wasn't that happy with only one available local.
Wire up wideband
Charge n fit battery
Do skids
So no not very much
  • Like 3
Yeah shoulder getting sore again, neck is just starting to get sore but could be cause not takin any meds today (trying to gauge the pain as they have given me really strong meds)
Some meds before bed time zzz.zzz.zookey!
Doc gave me tramadol last time I done the discs in the lower back. Was insane. Couldn't tell if I was awake or asleep? Took them for 4 days then jumped off them quick. Nasty as. Night terrors and sweating like a maniac. Scary.
Be careful of doctor trevs! Will be recommending more beers as a suitable treatment plan:-)
200mg morphine, very full on lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
