30 minutes ago, z00key said:
Yeah shoulder getting sore again, neck is just starting to get sore but could be cause not takin any meds today (trying to gauge the pain as they have given me really strong meds)
Ouchy, ur a brave man lol
  • Like 1
Ha gunna learn with the phantom 1st then go to mavic. Have a few ideas on what i want to do with them and was all to do with a shot that@t_revz said a while back, its a cool shot and been thinking about it ever since. I also have quite a few friends that are into photography some experienced and some new so gunna try see if i can get a group of em together for a photo session (for anyone keen feel free to let me know)
  • Like 3
Ha gunna learn with the phantom 1st then go to mavic. Have a few ideas on what i want to do with them and was all to do with a shot that[mention=24655]t_revz[/mention] said a while back, its a cool shot and been thinking about it ever since. I also have quite a few friends that are into photography some experienced and some new so gunna try see if i can get a group of em together for a photo session (for anyone keen feel free to let me know)
You can take some pics of my 4X4 ;)
9 hours ago, R33kizza said:
Think it was around 500ish, told the mrs what i needed and what website it was at and it appeared 2 weeks later lol
It would apear in my half asleepness that i didnt rear the question properly....
Radiator is all done, been driving it for 3 days as my daily is on holiday with a friend. Actual fit was ok once i got rid of the shroud and just fitted the fans to the rad direct. Temp guage sits on around the 1/3rd mark and goes to half on freeway. If driven around in traffic both all the fans come one and go of after arpund 20-30seconds.
Wouldn't mind some photos of the cars :D
  • Like 1
1 minute ago, t_revz said:
The car is alive again. Appears to be a bit rich during cruise. Had to lower injectors values to 80% at 110km/h to get to stoich. Hopefully fuel economy improves;)
Nice job, feel awsome to drive?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
