30 minutes ago, z00key said:
Yeah shoulder getting sore again, neck is just starting to get sore but could be cause not takin any meds today (trying to gauge the pain as they have given me really strong meds)
Ouchy, ur a brave man lol
  • Like 1
Ha gunna learn with the phantom 1st then go to mavic. Have a few ideas on what i want to do with them and was all to do with a shot that@t_revz said a while back, its a cool shot and been thinking about it ever since. I also have quite a few friends that are into photography some experienced and some new so gunna try see if i can get a group of em together for a photo session (for anyone keen feel free to let me know)
  • Like 3
Ha gunna learn with the phantom 1st then go to mavic. Have a few ideas on what i want to do with them and was all to do with a shot that[mention=24655]t_revz[/mention] said a while back, its a cool shot and been thinking about it ever since. I also have quite a few friends that are into photography some experienced and some new so gunna try see if i can get a group of em together for a photo session (for anyone keen feel free to let me know)
You can take some pics of my 4X4 ;)
9 hours ago, R33kizza said:
Think it was around 500ish, told the mrs what i needed and what website it was at and it appeared 2 weeks later lol
It would apear in my half asleepness that i didnt rear the question properly....
Radiator is all done, been driving it for 3 days as my daily is on holiday with a friend. Actual fit was ok once i got rid of the shroud and just fitted the fans to the rad direct. Temp guage sits on around the 1/3rd mark and goes to half on freeway. If driven around in traffic both all the fans come one and go of after arpund 20-30seconds.
Wouldn't mind some photos of the cars :D
  • Like 1
1 minute ago, t_revz said:
The car is alive again. Appears to be a bit rich during cruise. Had to lower injectors values to 80% at 110km/h to get to stoich. Hopefully fuel economy improves;)
Nice job, feel awsome to drive?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
