Used to do 13hr shifts and I'm sure we heard some songs 10+ times on redFM
I can't work at all without music but radio is last resort.
Digital radio at work mmm classic rock. Black Sabbath led zep doors acdc David Bowie Beatles rolling stones deep purple cheap trick guns n roses the cars Fleetwood mac heart chisel foreigner kinks etc. Dab
Yeah headphones in a workshop totally safe and endorsed by no workplace
My workplace has compulsory hearing protection at all times. I have muffs with inbuilt radio and an FM transmitter with a couple KM range. I usually only use it on night shift
Morning, doggie number ones at the vets being desexed. Bit emotional dropping her off and the other one keeps running round the house looking for her.
P.s... i got a 2nd dog, just realized id forgot to mention it befor
  • Like 3
29 minutes ago, colin.ssc said:
I use it to save myself from being annoyed by everyone else :)
Thats exactly why i have mine up loud, no ones comes within 15ft of my bay, no dealing with dumbass apprentices.... kids these days, therr getting dumber and dumber
  • Like 1
3 hours ago, colin.ssc said:
Apparently these days even if it's 10% cheaper to repair than write-off, it still gets approved for repairs.
Pretty much, but if a airbag goes off then its normally game over. Airbags, controle modules, blah, blah, blah
1 hour ago, shoey85 said:
Paint less dent removal is done now, halo efx is a custom colour like plasti dip but has a 2 PAC clear coat so it acts like paint, you can spill petrol on it, buff it ect
I get ya now
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
