6 hours ago, TiTAN said:
If you wanted it to be a race car you could buy it back and tube frame the front end.
No insurance or rego but no road use and id need a a daily to tow a trailer....
  • Like 1
If racing was cheap we'd all be doing it! I was lucky to afford the Nissan and only because I have a work d-max. What was it insured for? Shannon's? Any issues? I insured mine for 13,000 with Shannons but with what I've spent over the last year would be closer to 16,000. Your car looked really tidy. Better than mine. Suppose if you're already into a bombed rb30 engine would pay to buy it back?
Its agreed value of 10k with shannons. They have been briliant so far, tilt tray collectes at taken to my mates shop. I dont want to loose it, took me 8 months to find a near mint unmolested car, previous owner had her for 10 years. Racing is only as expensive as you make it ans the upside is its safer than any road and u can actualy use all the power it mite make
  • Like 2
Will make, fyp. Daimler/Benz torque figures;-)
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
