t_revz Posted August 25, 2017 Share Posted August 25, 2017 Aids?Musta caught it from hank[emoji8] 1 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846578 Share on other sites More sharing options...
t_revz Posted August 25, 2017 Share Posted August 25, 2017 Anything to do with beef pork or lamb and you're in:-) Beef -mince (tacos)Pork- bellyLamp- chopsNom nom nom Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846579 Share on other sites More sharing options...
TiTAN Posted August 25, 2017 Share Posted August 25, 2017 If my life is for rent.and I don't learn to buy. Do I deserve nothing more than I get. For nothing I have is truly mine. (Dido)The road I walk is paved in gold, to glorify my platinum soul. I am the closest thing to God, so worship me and never stop. Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846582 Share on other sites More sharing options...
TiTAN Posted August 25, 2017 Share Posted August 25, 2017 Musta caught it from hank[emoji8]The easiest way to tell if he got it from hank is to check his shoe and cap collection. 2 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846583 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 New engineDef not running richCams are mildOne of the injectors is ticking so most likely that's the culprit but I don't wanna upgrade to top feeds unless I'm sure. Bit of a weird issue. Damn trouble shooting takes time. I pulled mine off the road for 2 months after I got it. Started misfiring and wouldn't start. New Fuel pump. Rewired immobiliser. Checked injectors. Replaced coil packs. Plugs. Cleaned throttle body and intake. Flushed intercooler. Cleaned acc valve. 2x different cat converters. New exhaust. Fixed split dump. Castor arm bushes and rack ends, new oil feed and return turbo. Box diff and eng oil. Chased and checked all wiring. Swaged and pressure tested all intercooler piping and re-welded Fitted catch can and washer bottle. New pc valve. Radiator and viscous coupling. Assuming immobiliser and coil packs were the problem. Did so much at once don't really know what was wrong. Got a bit of belt noise now when cold so hope it's not the timing belt. Has a whodowah whodowah noise at idle now like something is struggling.? Thinking maybe the vacuum lines aren't quite right. Would like to get one of you guys to sus it out. Vented to atmosphere before but catch can isn't pressurising the crankcase? Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846584 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 Bit of a weird issue. Damn trouble shooting takes time. I pulled mine off the road for 2 months after I got it. Started misfiring and wouldn't start. New Fuel pump. Rewired immobiliser. Checked injectors. Replaced coil packs. Plugs. Cleaned throttle body and intake. Flushed intercooler. Cleaned acc valve. 2x different cat converters. New exhaust. Fixed split dump. Castor arm bushes and rack ends, new oil feed and return turbo. Box diff and eng oil. Chased and checked all wiring. Swaged and pressure tested all intercooler piping and re-welded Fitted catch can and washer bottle. New pc valve. Radiator and viscous coupling. Assuming immobiliser and coil packs were the problem. Did so much at once don't really know what was wrong. Got a bit of belt noise now when cold so hope it's not the timing belt. Has a whodowah whodowah noise at idle now like something is struggling.? Thinking maybe the vacuum lines aren't quite right. Would like to get one of you guys to sus it out. Vented to atmosphere before but catch can isn't pressurising the crankcase? On recirculation before the turbo impeller. Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846585 Share on other sites More sharing options...
z00key Posted August 25, 2017 Share Posted August 25, 2017 here is 1st meet point for those interested i believe it is at 11am with the cruise starting at 12 1 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846587 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 here is 1st meet point for those interested i believe it is at 11am with the cruise starting at 12 Saturday or Sunday? 1 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846589 Share on other sites More sharing options...
z00key Posted August 25, 2017 Share Posted August 25, 2017 Saturday or Sunday?Saturday Tomorrow (today depending on when u r reading this) saturday 26th 1 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846590 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 Saturday Tomorrow (today depending on when u r reading this) saturday 26thSee you there. Might even have time for a spit and polishing! Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846591 Share on other sites More sharing options...
TiTAN Posted August 25, 2017 Share Posted August 25, 2017 Might even have time for a spit and polishing! Surely there's plenty of time left for a wank before the cruise. No might about it. 2 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846592 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 Surely there's plenty of time left for a wank before the cruise. No might about it.Just hit the hay with Rias Gremory My body pillow. Wife is asleep. Stop interrupting, can't concentrate:-o Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846593 Share on other sites More sharing options...
D_I_F Posted August 25, 2017 Share Posted August 25, 2017 That's why you stopped byYep Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846595 Share on other sites More sharing options...
shoey85 Posted August 25, 2017 Share Posted August 25, 2017 here is 1st meet point for those interested i believe it is at 11am with the cruise starting at 12 I'm in rocky at 9 so probably won't have enough time to zoom back to midland by 11-12 plus only have the Prado atm 2 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846601 Share on other sites More sharing options...
Beyond Blue R33 Posted August 25, 2017 Share Posted August 25, 2017 I'm in rocky at 9 so probably won't have enough time to zoom back to midland by 11-12 plus only have the Prado atmFrom rocky fyp Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846602 Share on other sites More sharing options...
TiTAN Posted August 26, 2017 Share Posted August 26, 2017 A 29-year-old man has been arrested and charged with unlawful possession after police uncovered hundreds of avocados at his home in rural Australia.The startling discovery was made on Thursday, when police searched a home in Renmark, South Australia.Officers found a number of items suspected of having been stolen during break-ins throughout the Riverland region, including antique clocks, building insulation and a canoe.But while the owners of those items have been identified, no-one has claimed the hundreds of avocados located at the same address Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846616 Share on other sites More sharing options...
R33kizza Posted August 26, 2017 Share Posted August 26, 2017 12 hours ago, t_revz said: Beef -mince (tacos) Pork- belly Lamp- chops Nom nom nom Beef - mince (chilli with nachos) Pork - apple and cider susages Lamb - lamb madras, popadoms and naans 1 Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846638 Share on other sites More sharing options...
R33kizza Posted August 26, 2017 Share Posted August 26, 2017 4 hours ago, shoey85 said: I'm in rocky at 9 so probably won't have enough time to zoom back to midland by 11-12 plus only have the Prado atm Playing bogan again? Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846639 Share on other sites More sharing options...
R33kizza Posted August 26, 2017 Share Posted August 26, 2017 11 hours ago, Beyond Blue R33 said: Just hit the hay with Rias Gremory My body pillow. Wife is asleep. Stop interrupting, can't concentrate:-o Is that the left or right hand? Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846640 Share on other sites More sharing options...
R33kizza Posted August 26, 2017 Share Posted August 26, 2017 12 hours ago, Beyond Blue R33 said: Bit of a weird issue. Damn trouble shooting takes time. I pulled mine off the road for 2 months after I got it. Started misfiring and wouldn't start. New Fuel pump. Rewired immobiliser. Checked injectors. Replaced coil packs. Plugs. Cleaned throttle body and intake. Flushed intercooler. Cleaned acc valve. 2x different cat converters. New exhaust. Fixed split dump. Castor arm bushes and rack ends, new oil feed and return turbo. Box diff and eng oil. Chased and checked all wiring. Swaged and pressure tested all intercooler piping and re-welded Fitted catch can and washer bottle. New pc valve. Radiator and viscous coupling. Assuming immobiliser and coil packs were the problem. Did so much at once don't really know what was wrong. Got a bit of belt noise now when cold so hope it's not the timing belt. Has a whodowah whodowah noise at idle now like something is struggling.? Thinking maybe the vacuum lines aren't quite right. Would like to get one of you guys to sus it out. Vented to atmosphere before but catch can isn't pressurising the crankcase? Ur supost to do it bit by bit so u found the fix not juat change everything lol il stick my head under the hood next time were at a meet Link to comment https://www.sau.com.au/forums/topic/456618-new-wasteland-wa-topic/page/616/#findComment-7846641 Share on other sites More sharing options...
