If my life is for rent.and I don't learn to buy. Do I deserve nothing more than I get. For nothing I have is truly mine. (Dido)
The road I walk is paved in gold, to glorify my platinum soul. I am the closest thing to God, so worship me and never stop.
New engine
Def not running rich
Cams are mild
One of the injectors is ticking so most likely that's the culprit but I don't wanna upgrade to top feeds unless I'm sure.
Bit of a weird issue. Damn trouble shooting takes time. I pulled mine off the road for 2 months after I got it. Started misfiring and wouldn't start. New Fuel pump. Rewired immobiliser. Checked injectors. Replaced coil packs. Plugs. Cleaned throttle body and intake. Flushed intercooler. Cleaned acc valve. 2x different cat converters. New exhaust. Fixed split dump. Castor arm bushes and rack ends, new oil feed and return turbo. Box diff and eng oil. Chased and checked all wiring. Swaged and pressure tested all intercooler piping and re-welded Fitted catch can and washer bottle. New pc valve. Radiator and viscous coupling. Assuming immobiliser and coil packs were the problem. Did so much at once don't really know what was wrong. Got a bit of belt noise now when cold so hope it's not the timing belt. Has a whodowah whodowah noise at idle now like something is struggling.? Thinking maybe the vacuum lines aren't quite right. Would like to get one of you guys to sus it out. Vented to atmosphere before but catch can isn't pressurising the crankcase?
On recirculation before the turbo impeller.
1503675438482.thumb.jpg.133c0bfa16106457f2e88ef975a0a511.jpghere is 1st meet point for those interested i believe it is at 11am with the cruise starting at 12
I'm in rocky at 9 so probably won't have enough time to zoom back to midland by 11-12 plus only have the Prado atm
  • Like 2
A 29-year-old man has been arrested and charged with unlawful possession after police uncovered hundreds of avocados at his home in rural Australia.
The startling discovery was made on Thursday, when police searched a home in Renmark, South Australia.
Officers found a number of items suspected of having been stolen during break-ins throughout the Riverland region, including antique clocks, building insulation and a canoe.
But while the owners of those items have been identified, no-one has claimed the hundreds of avocados located at the same address
Ur supost to do it bit by bit so u found the fix not juat change everything lol il stick my head under the hood next time were at a meet
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
