Gazebo. Or as I like to call it the white elephant. Wife had too have it. Brand new, never been used, no joy riders low ballers or time wasters. DSC_0315.JPG.5f92282c373ab30fb15b9cd82cbc2e93.JPGDSC_0317.JPG.72825973a1ab5f50dd25fac81a0bf604.JPGDSC_0316.JPG.be990c31d3136a28471933744a36c515.JPGchews more oil than a ls1:-o
Dad reconds if there is a earthquake or cyclone head out to the gazebo or patio. Totally over engineered.
  • Like 1
The cubby I built for the kids at our last house could hold a herd of elephants [emoji208]
  • Like 3
Will how convenient. Wondered if i may ask a favour if anyone knows and could help. My front lounge is open living and we would like to put doors on the 2 entries/exits anyone know how i would go about doing this? Would it be a hard jod to do or be able 2 give me a hand to do it?
A full herd of white elephant ridiculousness, the sheer irony is that the gazebo replaced the kids old cubby house. 90x90 timbers fully concreted and solid braced floor. Pine paneled door, windows, eaves out on to a small patio. Stud frame and full weather board inside and out. Full corrugated green roof to match the house. I slept in it a few times while drinking beers and listening to the radio in raging bad weather to sheerly justify the amount of work and expenses. Kids never used it! Fully funny to hear a similar experience. I lost my s##t. Again!
20170901_181439.thumb.jpg.784d04faeeb0f9bfbc71bd8c4b540738.jpg20170901_181431.thumb.jpg.86c5e61a41cf45adf8fa6509fb4298cf.jpg
The doors you get at bunnings/masters etc. Are generally only a generic size. You would need to put a architrave in (metal or wood) the metal architraves generally have the hinges built into the frame work. The first pic looks like a bigger width than normal. The second pic looks pretty standard. From memory doors are normally. 715mm small 815mm large. Could be 720, 820. Then once the architrave is in you just plane them down to suit because the doors have thicker wood on the outside the internal frame. You also have to fit the door handles and cut out the locking mechanism into the architrave.
I prefer working with metals, fuxk it up and u can weld a bit on. Cant do that with wood lol
  • Like 2
These 2 doorways am wanting to put doors on
Buying generic pre hung doors is easiest. As you don't have to work out the hinges etc. You can probably get them with hardware pre installed too at a bit of an extra cost.
put the door and frame into the opening and then make a bit of frame work around them to join them solidly with the edges of the opening/roof/floor. Leave yourself a small margin around the door for spacers to align the door. cover the frame work in plaster board, go for gold with the joint compound and spread it reasonably wide (~10cm wide over the join and don't be afraid to do a bit of sanding, then go for the finer top coat at ~20cm wide and sand again, it makes it harder to see there is a bump. Going too narrow makes the bump more visually obvious).
you may need to take some plaster board off around the edges of the existing openings to remove any plastic/metal reinforcement pieces on the corners for a better finish.
The most important thing is to take your time getting the door in the correct spot before you screw it in properly (square/straight) so the door stays where you open it to instead of naturally wanting to swing open/closed.
If you want pocket doors then that's a whole world of hurt to retrofit, just pay a pro to do those.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
