32 minutes ago, shoey85 said:
How was this a write off, ours was way worse!!
Insured for 10 and the quote was over that, assesor didnt even go out to see the car lol.... what did urs come to? Insured for more than mine id guess?
Only insured for 12,500, 8K for repairs but we are getting the full respray including wheels done for 3500 on top of that
Thats pretty gd, i think mine came to 9ish. Iv gotta go pick up the quote to see what i need. Gonna try use a ratched strap to pull it out tomoz, rad support is pretty soft, pulled it out a inch by hand lol
Big 2 days of inspecting cams on dump trucks as they have 20,000 hours and starting to break down often
Big'uns? Caterpillars? Ive just clocked up 42 years and starting to break down often:-(
3516
Yep she's a big girl, have some pics of a dual 10" exhaust and new charge air tubes I made for westrac out at there dyno room. But can't upload them. What were the results? Worn lobes?
Quoted a job for westrac today. Fix all there charge air intercooler box with all new 8" to 7" breeches pieces to 7" tubing off the turbo's for c175-20 engines. Even with massive swages and tripple clamping they are popping the hoses under 32psi boost. We've chased it down to the weekest link which is where the 8" reduces to a 7" breeches piece after the intercooler and into the intake manifolds. Have done 2 x fixes already. Hope we pick up the job. It's a big job that I've honestly quoted. Will be all new tube work and a full new reconfiguration. They are expanding size from the turbo's to the intercooler, but reducing too much on the way back to the manifolds. So far as I'm concerned. I've suggested 3 x fixes but in reality it needs all new tubing. I love working with the guys at westrac, they know there stuff. Which makes my job easier.
Can even be related back to the skyline. Turbo outlet is 2" I/d and 2 1/2" od. 2 1/2" tubing to 3" intercooler so the air has a pressure drop then expands through the intercooler and fills with mass for air cooling then compresses back to 2 1/2" into the throttle body. With a 3" intake to match the size of the intercooler. You've just got to love the principals and practices of turbo charging. It's the reason our Nissan's are animals. :-)
They are big donks! And they sound mint!!
Yep I'm ex-westrac so I'll claim that compliment [emoji12]
  • Like 1
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
