Mate you would be shocked (its horrible) if you saw my work tonight, fkn dogs been chewing on the doors for a while so I had to sort it out today when I saw one in the garage after work.
Not too bad for a paper pusher in a West Perth office!
By day Martin the paper pusher by night under his secret alias Shoey the sheety. I thought it looked pretty good ;-)
  • Like 2
34 minutes ago, R33kizza said:
I think you got issues.....
It's a newish battery too. Bought it about 8months ago. Got the cat jumped and drove it home (another 30minutes) the battery wasn't charging at all. On Tonkin if I flicked my lights on my electrics would turn off, even the stereo.
Got her home. Shut the engine off and immediately tried to start it. Nothing. Completely flat .
  • Like 1
Charge up the battery check the voltage with a multi meter it should be about 13ish volts at full charge. Put the battery in the car start it and with it running it should be about 14.2 to 14.4v this will prove if the alternator I's charging the battery. If it has a external voltage regulator you will only need to replace the regulator. If it's built in new alternator? Cheapie multimeter is only about $30. What cca is the battery? Check the water level and make sure the cells are covered with distilled water.
  • Like 1
Does the battery light on the dash come on?
  • Like 1
DSC_0120(1).JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
  • Like 1
DSC_0120(1).JPG.f5f30fe11e8e050c32e5a76cf64df835.JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
The car will run with no accessories for ages if the alternator isn't charging the battery. It's the accessories that will kill it. Stereo lights a/c etc.
  • Like 1
You've got a charge issue mate and probably battery is fine.
Does batt light come on with key on them go off when started? Is the fan belt tight? Sometimes the belt can slip without making much noise.
  • Like 2
External regulator?
The 70's are over mate!! Welcome to the 21st century :)
  • Like 1
Would have to be insanely loose to not turn the water pump and alternator?
It could be the battery, car wouldnt run if the alternator wasnt charging. Batterys can collapse at any time. Is it hooked up to a trickle charger at all? Worse things in the world for batterys, slowly cook them to death....
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
