Mate you would be shocked (its horrible) if you saw my work tonight, fkn dogs been chewing on the doors for a while so I had to sort it out today when I saw one in the garage after work.
Not too bad for a paper pusher in a West Perth office!
By day Martin the paper pusher by night under his secret alias Shoey the sheety. I thought it looked pretty good ;-)
  • Like 2
34 minutes ago, R33kizza said:
I think you got issues.....
It's a newish battery too. Bought it about 8months ago. Got the cat jumped and drove it home (another 30minutes) the battery wasn't charging at all. On Tonkin if I flicked my lights on my electrics would turn off, even the stereo.
Got her home. Shut the engine off and immediately tried to start it. Nothing. Completely flat .
  • Like 1
Charge up the battery check the voltage with a multi meter it should be about 13ish volts at full charge. Put the battery in the car start it and with it running it should be about 14.2 to 14.4v this will prove if the alternator I's charging the battery. If it has a external voltage regulator you will only need to replace the regulator. If it's built in new alternator? Cheapie multimeter is only about $30. What cca is the battery? Check the water level and make sure the cells are covered with distilled water.
  • Like 1
Does the battery light on the dash come on?
  • Like 1
DSC_0120(1).JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
  • Like 1
DSC_0120(1).JPG.f5f30fe11e8e050c32e5a76cf64df835.JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
The car will run with no accessories for ages if the alternator isn't charging the battery. It's the accessories that will kill it. Stereo lights a/c etc.
  • Like 1
You've got a charge issue mate and probably battery is fine.
Does batt light come on with key on them go off when started? Is the fan belt tight? Sometimes the belt can slip without making much noise.
  • Like 2
External regulator?
The 70's are over mate!! Welcome to the 21st century :)
  • Like 1
Would have to be insanely loose to not turn the water pump and alternator?
It could be the battery, car wouldnt run if the alternator wasnt charging. Batterys can collapse at any time. Is it hooked up to a trickle charger at all? Worse things in the world for batterys, slowly cook them to death....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
