Update, we should have it back next week, there is still a lot of work to do, all the front end wiring needs to be redone as it was ripped out, wheel alignment, re buff the whole car, apply window tinting, re gas the aircon system.
  • Like 2
Looking pretty gd! Cant wait to see it ?
  • Like 1
I don't want to be that guy, but, I was taught that you're not supposed to buff a car for at least 3 months (normally 6) because the paint has to de-gass.
Edited by Manne
CAR IS LOOKING HOT BTW ♥ ♥ ♥ ♥
He’s the expert I trust his judgement, also my brother is a painter and said they do it all the time at the shop so it can’t be that bad for it
It depends on how the car is baked, there are baking techniques which allow the gasses to escape faster.
Just now, shoey85 said:
Bloody hell its Hanky, between the Doggo
And the Misso I thought we’d lost ya!
Happy Friday bloke, any plans for the weekend?
I heard there was a football match on, might check that out.
What about you?
I'm considering buying a 4WD which might impress you Martin. Trev might also be impressed because it will most likely be a dirty DIESEL.
  • Like 2
What about you?
You know the way to my heart!!
I may go 4x4ing since we are still waiting for the R34!!
What game, I don’t follow men hugging on a grass field
  • Like 1
I sure do! Hopefully in the new year I can tag along on a 4wd trip with you.
Some birds are taking on some cats in Melbourne apparently.
  • Like 1
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
