Team diesel 4wd took another step forward today!
With any luck in 8 or 9 days I'll have thrown all my money away and purchased another car.
So, with that in mind, anyone wanna swap $20k for a 20B?
No more blap?
  • Like 1
Feeek I bet maintenance costs on that are not cheap at all!!!
No, they are hideously expensive to maintain.
A set of front pads and wiper blades installed at a dealer will set you back $800 according to a friend that owned one for a few months (and that was only the v6 diesel version), he sold it after getting that bill and working out how expensive maintenance items were going to cost long term.
I'm sure I can do pads and wiper blades at the shop, lol.
And a V6 diesel? Ewww!
Sounds like most german cars lol
It's ok , cost me about $220k for 3x2 ( deluxe condominium) so it's affordable:)
How much is in Japan ?
Similar to that to build in the country, but very cheap to buy an old house.
Not sure in the city but no doubt expensive even for a shoe box
  • Like 1
True , old House much cheaper But Then You need to do lot of repairing works [emoji20] hence I bought the new one , mind you brand new house is completely empty as in no kitchen cabinets or wardrobe in the bedrooms - no lights and fancy accessories, just marble floors , once they release the house key I need to do lot of renovations [emoji849]
Morning All ! I haven't start the R35 for ages , I think it's the battery completely or something else! Very convenient especially when I plan to have a look at the Nismo [emoji15]
Morning chick!
Could be battery you with RAC?
  • Like 1
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
