32 minutes ago, ElleAli76 said:
Thanks!
I also need to sort out some house cleaning with you while I'm away on holidays, I'll give you a call later :)
  • Like 1
Just now, Manne said:
Everything is fine as far as I know, his baby is due in 2 weeks? so i'm assuming baby prepping is eating up all of his time.
2 weeks? That doesn't leave him much time to push his missuz down the stairs... ¯\_(ツ)_/¯
  • Like 1
[mention=143902]shoey85[/mention] [mention=139458]ElleAli76[/mention]
M
Thanks for the info Manne, would
Like visit him if he's around
  • Like 1
Thanks!
I also need to sort out some house cleaning with you while I'm away on holidays, I'll give you a call later [emoji4]
Anything for You darling ! Just Give me a Call , Also where You going ?
Just now, ElleAli76 said:
US ? !!!!! oh Im So jelly ! You old men - go and have fun xx
Thanks, we will! If you need me to grab anything while I'm over there just let me know :)
  • Like 1
Thanks, we will! If you need me to grab anything while I'm over there just let me know [emoji4]
Only if You go New york :) Is Errin going with You ?
Anyway Im off to guthrie Street to See Phil, I should made it on time [emoji121]️
  • Like 1
Anyway Im off to guthrie Street to See Phil, I should made it on time emoji121.png
LA and Vegas with Keith from work.
  • Like 2
1 minute ago, shoey85 said:
Remember what happens in Vegas stays in Vegas except for AIDS that shit will come home with you!
Can't catch it twice m8 ;)
  • Like 2
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
