12 hours ago, shoey85 said:
Hey mate it was poxy hardly worth the drive down tbh, other than that the weekend was good, how was yours?
If i hadnt been busy with Owens appointments i would have gone for a look, mostly to see the caravan accessory stuff though.
Saturday i had heaps of dad duties, Sunday and today i trained the missus to be my T/A at building retaining walls. We built a 25M long curved wall from the driveway to the shed and didn't have a single argument haha
  • Like 2
Who’s up for a SAUWA trip to Bunbury to see old boy[mention=24655]t_revz[/mention] have a meal hang out for the day then head back?
Also@t_revz when’s a good date?
every 2nd weekend. ive just had this one off
3 hours ago, Beyond Blue R33 said:
10 hours ago, Hank Scorpio said:
Trev and Corey equally. It's the red hair that really boils my potatoes.
How many rangas are on this forum? :-o
not enough :banana:
  • Like 1
Wtf? Surely she knew better.
2 hours ago, Beyond Blue R33 said:
2 hours ago, R33kizza said:
Evo powered family mover!!!
Flat knacker squid run down the mountain pass. Not a square of tofu in sight;-)
mother asleep in the backseat?
she knows nothing about building and usually asking for help starts WW3
  • Like 2
Did u get her in a gd mood first? ? Il do you a favour, you do me a favour... nudge nudge wink wink ?
1 minute ago, Beyond Blue R33 said:
D.I.Y....... Now. Show us your wall.
ill take a pic in the morning if its bright enough, otherwise after work
If you didn’t make it then don’t be upset it was pathetic we went around the whole thing in 33mins!!
The big one is in Perth in November if your around that weekend?
  • Like 1
We are married... it doesnt work like that anymore haha
she just wants it done so we can put lawn down... plus all them monies saved $$
ahh ill be working that weekend :(
  • Like 1
Im married, my wife knows its the best way of getting me to do shit, specially shit i hate doing lol
7 minutes ago, R33kizza said:
Tied up in the boot, too much talk of ur raising ur kids wrong ???
haha was actually referring to the kid in Inital D s6 who learned to drift while his mum slept in the backseat haha
  • Like 1
2 minutes ago, shoey85 said:
If you didn’t make it then don’t be upset it was pathetic the whole thing was 3inches
The big one is in my pants if your around at the weekend?
Pardon?
  • Like 2
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
