I’ve got radio earmuffs that I wear on the bobcat. Last week I heard a weird noise and thought the radio wasn’t tuned in properly. I took them off a minute later and realized there was a spider caught in the seal. Scared the bloody crap outta me [emoji887] haha
Haha, building a Web in you're ear hole minding it's own business.
On a more serious note lol, stick it gear and try and push it. If it moves u kniw its clutch for sure. Chances are its a dead slave or master
Slave cylinder over stepped the fork and knocked it of the pivot ball. Cause master cylinder. Clutch looks new no damage. Yeay. Turboedsloth and kizza correct. Show us your forum! ;-)
3 hours ago, Beyond Blue R33 said:
On 01/11/2017 at 10:03 PM, R33kizza said:
Iv got 2 spare rb blocks..... lol
With rods hanging out the side for authenticity :-S
Blocks are all gd and servicable. The 25 is bored to .5 ready for a set of rods and pistons and so is the 30 which is what will hopefully end up in my car!! Possibly... mabe.... lol
  • Like 2
Would be fearfull of any kizza beast:'(
In time!! Move into my new house 2 weeks today, cars half way down the list of jobs to do..... ?
  • Like 3
In time!! Move into my new house 2 weeks today, cars half way down the list of jobs to do..... [emoji52]
Damn responsible adulthood, been helping my mate Craig with his cortina. 250 yella Terra head, 500 holly, top loader 9" Tc xle. Seen that bad boy with the exhaust and brakes glowing red during apprenticeship.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
