3 minutes ago, Beyond Blue R33 said:
22 hours ago, t_revz said:
You should have a rest and do a small job
Got Eli's old exhaust sitting near the stainless scrap bin. 4 x 3" tips sticking out from under the rodeo tray.
HAWT!!!
  • Like 1
3 hours ago, t_revz said:
Trying to get behind a desk so you can whore SAU all day...
Again?
Well, not right away.
Getting a shiny new zipper installed along the spine next thursday, but that is the plan eventually
19 minutes ago, Beyond Blue R33 said:
5 hours ago, Stinky Rooster said:
so, who does your drawings and does he need help?
Nope it's my office. No one smarter or better than me allowed in ever. I guard that office and computer like a ravenous pit bull terrier. Any chance to get off the floor and I'm in there. :-) air conditioner soaking up even a very mild sweat.
I do a pretty mean shop detail, just saying
9 minutes ago, t_revz said:
boilys working up a sweat... no way
I was going to be a boily
but Dad said I had to do a trade ;)
  • Like 3
speaking of trades, i thought if you dont ask, you dont get... chatted to the boss and they have agreed to pay for me to officially get dual trade.
Westrac are going to assess me and see what modules they think i require to compliment what ive already done
  • Like 1
but Dad said I had to do a trade [emoji6]
That's why I'm a sheetmetal worker by trade. The young fella from work is a boily. Bash hammer whoops can u please have a look at this? Oh Mr. Hart what a mess.
  • Like 1
Haven't had a boilermaker through the shop in the last 15yrs that can do a parallel/radial/triangulation pattern. It's a dying art. Which makes me a expensive dinosaur.
I made a offset conical reducer a few weeks ago and a oval to round reducer last week out of 2mm 316 s/s. Explained it to the lad and he was like yep. I will never understand that. Quality of trades is going downhill big time.
For boily/welding on top of auto electrician? Or mechanical fitting? My bro has auto electrics/ electrician and mechanical fitter. I've always wanted to officially get my cad and refrigeration mechanic ties in well with sheety.
Did you tell him moar bits of paper = moar money?
Or he just smiled as if to say hey Trev you're f**king good. Trev me mate the master farter broke new ground in breaking wind with his double jointed ass:-)
Auto sparky/diesel fitter. I’ve already done hydraulics, air con, welding modules so hopefully it doesn’t take another 4 Year’s to sort it out
  • Like 1
Sweet. The bro does 2 on 2 off, auto sparky/electrician/diesel fitter. 160.000 per annum. He can troubleshoot anything. I have more respect for that man than any other tradesman I know. Cats Cummins mtus Waukesha wartzilla diesel gas locomotives power generation. He has a bedroom at home with dedicated model train sets on all the locos hes worked on. Animal
I dont have any children, both loinspawn are fully fledged adults now.
Me and the grandsprogs wiill be setting fire to a playground near you soon
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
