Sweet. The bro does 2 on 2 off, auto sparky/electrician/diesel fitter. 160.000 per annum. He can troubleshoot anything. I have more respect for that man than any other tradesman I know. Cats Cummins mtus Waukesha wartzilla diesel gas locomotives power generation. He has a bedroom at home with dedicated model train sets on all the locos hes worked on. Animal
Sounds like a clever Kent. 160k isn’t that much for someone with so many qualifications and doing FIFO
I’ve got a restricted high voltage ticket aswell but I’ve never had to actually use it so I don’t have any experience. Hopefully I automatically qualify for a lot of the criteria so I can skip through the training easily
  • Like 1
22 hours ago, Beyond Blue R33 said:
On 21/11/2017 at 8:08 PM, R33kizza said:
I know how you feel, moved houae at the weekend and been doing 4 hours ot a day. Working 6am till 9pm tomoz..... fml
15hrs pretending to be a German might not be germain to the situation. Just try to avoid their porn. Sebastian vettel calenders everywhere :-o
10.5 hours ot in 2 days.... tired doesnt even touch it! However the 135i sat on my drive is kinda nice lol
  • Like 1
I sell things. :)
  • Like 1
Dad's mate had a e46 m3 man that n/a 6 delivered power beautifully. You know, when it wasn't broken down. Dave's nephew just bought a xr6-t out of the yard at midway ford. Dyno at 400rw/kW. Still on p's. Hope he lives to tell the tales.
Faster than a speeding bullet, moar powerful than a locomotive, leaps to air-conditioning in a single bound. It's that fat ranga welding guy.
Dunno if I could handle being in an office full time... too many muppets
Temporary Australian
  • Like 2
Lucky it's summer. Imagine the boost spooling up with the button off in the wet. I've busted traction 3rd to 4th in the xr8 and the skyline in mildly damp conditions. At least the Nissan is direct and pointy when having to pedal it. The falcon has lovels Springs Koni shocks and adjustable sway bars but is still the worst understeering dinghy ever. That massive 5.4 quad cam engine is a f**king boat anchor compared to the Windsor's I've owned. High front centre of gravity. Still the wife's favourite thing. Makes moar noise. Thinks shes a legend shifting at 4500.
Not reli a bmw fan but thr 135 is a twin turbo 6pot, 300hp and there reli light.... gd fun. The motors gd for 500hp on factory injectors and internals. Turbos not to much but its engine out to change them lol....
Id contemplated a fg xr6t to replace the skyline but there so damn heavy... 1800kg.... fat sloth
Heavy yes, but a couple mods and it's putting down 350rwkw. A few more and it's pushing towards 400. all without touching the stock turbo.
that barra motor is a heavy mofo but makes power so effortlessly.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
