1 hour ago, Hank Scorpio said:
Slowly convincing my parents to become crazy greyhound people like me ;)
You are saving humanity, one dopey pooch at a time, bro
Elle - been smashing the bread products this week, and they dont photograph anywhere near as well.
  • Like 1
They taste amazing tho.
33 minutes ago, Hank Scorpio said:
Dale - I haz 23rd December to 2nd January off, we will have to do a BBQ one day after Christmas.
I am down like an extra chromosome, broseph.
BTW - The Good Wife asked me if I have to have the bbq sauce on everything I eat
and the answer, of course, is yes. Yes I fkn do.
  • Like 1
Hahahaha! Glad you like it.
1 minute ago, shoey85 said:
Fk mate I woke up last night thought I was poisoned fkn dog farts are ranks as!
They are the worst!
I don't think Hank's high protein diet mixed with his fast metabolism helps :/
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
