8 minutes ago, Hank Scorpio said:
Ugh, importing cars from America is way harder than Japan. Now I have to worry about asbestos!
in the brakes or in the body armour?
anyway, you think you got issues?
I just got one of those phone calls, where the bloke on the other end has assumed you have a bit more knowledge than you actually do, on a given subject, and you spend the entire conversation catching up....
Turns out I have a job interview on friday. Exactly 1 week after having my spine fused
Job interview is good though!
I'm not sure, we will see what the Iron Chef says...
1 minute ago, Stinky Rooster said:
Ken oath it is, but tbh I had kinda counted on a little more down time :(
Yeah, it's pretty fkn close :/
You might have to have a shave! :O
Ken oath it is, but tbh I had kinda counted on a little more down time [emoji20]
Well I didn’t start my current job for 3 months after the interview so you might have time if they are as shit useless and unorganised as our HR people
If you don't follow this facebook page, you should it's hilarious!
https://www.facebook.com/KTEBMADS
What isn't hilarious is that so many people don't understand sarcasm :( (Some of the comments, wow.)
  • Like 1
What isn't hilarious is that so many people don't understand sarcasm [emoji20] (Some of the comments, wow.)
I find the bell tower times quite amusing
Wanna substitute for a couple weeks then you slide in when your better
We’re both good looking so they’ll never know ?
Our HR averages 5 1/2 months from applications closing. I was hired 5 months after applying. So many times I thought I never got the job
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
