11 hours ago, Stinky Rooster said:
coffee pods are the devil. They have the WORST coffee in them - the one at work actually trys and uses the fact that it has robusta beans in it as a positive :cry:
Plus, the stupid amount of packaging waste they make is one of the things the next generation is gonna be pretty pissed about, and I cant say I blame them
I send all my nespreso pods bk to be refilled.... sold my bean machine cuz it was to much hastle lol
I didnt even know that was a thing :O Kudos for that dude,
But I fkn love my beans, but if they havent been ground juuuust before the brew, I can taste it. Getting my little french press and cheapy grinder together for the big journey to work on Monday. That office is finally going to find out what decent coffee smells like.
  • Like 1
Blend 43!!
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
