R34 the Manual is so good, think my 4th synchro may be on its way out.
215 as an auto then 245 as a manual he said he did see 250 on one run but couldn’t find it, also he didn’t do a full solid power run for show.
Next time or any dyno days coming up would be keen for a run!
Now I want to go for a cruise in the hills!!
  • Like 4
Pinjarra usually has a car show and dyno day around April. I’ll be there to spectate
  • Like 2
Yeehaa! Do a sick burnout init G..... ?
  • Like 1
Awesomeness Martin. How heavy is the clutch?
  • Like 1
Yeah I’ll put some glitter on em
A classical guitar with no amp distortion pedal or plectrum. Gee thanks dad. I really really wanted a drum kit:-o. Get him into lessons, bad habits are hard to break out of. Drumming,drinking,smoking etc.
Haha I haven’t got him a pedal.amp or pick yet lol
  • Like 1
You should start beating on the drums
SAUWA animal!!
I’ll swap ya. You’ll be squatting triple your body weight just with your left leg in no time
Haha nah f**k that, that’s why I went for the exedy fullface organic with hydraulic clutch actuation
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
