R34 the Manual is so good, think my 4th synchro may be on its way out.
215 as an auto then 245 as a manual he said he did see 250 on one run but couldn’t find it, also he didn’t do a full solid power run for show.
Next time or any dyno days coming up would be keen for a run!
Now I want to go for a cruise in the hills!!
  • Like 4
Pinjarra usually has a car show and dyno day around April. I’ll be there to spectate
  • Like 2
Yeehaa! Do a sick burnout init G..... ?
  • Like 1
Awesomeness Martin. How heavy is the clutch?
  • Like 1
Yeah I’ll put some glitter on em
A classical guitar with no amp distortion pedal or plectrum. Gee thanks dad. I really really wanted a drum kit:-o. Get him into lessons, bad habits are hard to break out of. Drumming,drinking,smoking etc.
Haha I haven’t got him a pedal.amp or pick yet lol
  • Like 1
You should start beating on the drums
SAUWA animal!!
I’ll swap ya. You’ll be squatting triple your body weight just with your left leg in no time
Haha nah f**k that, that’s why I went for the exedy fullface organic with hydraulic clutch actuation
  • Like 1
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
