Oh, here is a photo of the freshly washed R33 4 Door, nearly ready to get some plates slapped onto her. (not embedding because the photo is huge)
Theres so much bird poo burn on her, as well as weird stains that I just couldn't remove and some weird blue-tacky glue stuff that's somehow leaked onto her. My current tools were not able to remove those.
Also plenty of scrapes and dings but hey.... the car was less than $3k and I'll sort those out in time.
http://i.imgur.com/2L4mPAo.jpg
Current plan: Mesh Grill, Remove rear Window Tint and Fit the Wheel Arch Guards. Then either drag my mate around to fix the Electrics, or if he really can't make it, drive the car to KYP, have them fix the electrics and prepare her for the pits.
Take Car over Pits, Get Licensed. If the car doesn't get licensed, fix whatever they want and take it back.
After that I need to save some cash, and then I move on to fixing the body and adding a few things (Reverse Camera, new Head Unit), and then we shall see about making the car perform better.
  • Like 1
Not bad... For a 4dr
Reverse camera? Moar powerz!!
The car has a front mount intercooler, GFB bleed valve, Splitfires, Pod Filter. It's currently running the stock Turbo and BOV. It's also had the Oil Filter re-routed for easier access.
Here is a photo of the engine bay, taken just before I fixed the leak: http://i.imgur.com/8AMJuJm.jpg
Did I mention it was rebuilt 50,000km's ago and was resprayed candy apple red? along side all new piping (which was tig welded, but needs a polish).
It's plenty fast enough for now.
Truthfully, I have no idea what to do with the engine...bigger turbo? aftermarket B.O.V?, ECU + Tune?.. no idea yet.
Things I definitely want: Coilovers and Sway Bars, New Breaks + Rotors, Braided Break Lines.
edit: fixed some bad spelling
Edited by Manne
  • Like 1
Def ask before spending on engine. Trap for new players is that many advertised parts on eBay etc are crap. Not crap built but design. Standard bov is fine
Many threads with newbies who bought a tone of cheap engine parts then join Sau to find out why their car comes onto boost at 6500rpm and only has 250hp, if it didn't blow up first
Good plan right there. 25's respond to minimal mods half the time, quality high mount/manifold/gate/exhaust/injectors/ECU. Got one down here putting out 600hp with standards internals bar head gasket and cams
  • Like 1
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
