Thanks Justin. Its curved TV? Can it be mount on the wall and use the same bracket that I have on now ?
Oh and how's your new cleaning tools with in laws car ? And what tool was it ? Exciting ! x
The TV can be mounted using regular mounts, theres a very good chance your existing brackets will work.
New cleaning tools are very good, but I didn't get to use them today, for once the NBN installers were 2 hours early, so I didn't need to be at my in-laws at all. Friday is my next day off, so I'm going to go all out on my Skyline with them instead.
The Orbital Buffer I wanted wasn't in stock though, hopefully picking it up Friday morning.
  • Like 1
I'll have a look what tele I've got and check online if the brackets are compatible or if I need new one install
The cleaning Kit[emoji7] McG. I have some of them too.
@ElleAli76 the tv does go down a lil cheaper so here is the break down rrp is $3496 sale price is $2496 (today only) and staff price is $2372 (again its today only)
That's is a good price !!! Hanging there , forward this message to Dave [emoji1345]
What would be a good laptop to look at getting?
My current one is slowly dying after 10yrs of use. Will be used for mainly downloading music/ movies/ and engine/transmission tuning software
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
