Side Door BBQ is probably my favourite restaurant at the moment (had brekky there again on Sunday). It's in Highgate on Beaufort Street so nice and central. https://www.instagram.com/sidedoorbbq/
On weekends they do a breakfast/lunch menu until 3pm and have a massive centre table for a large group booking. I was thinking we could do a brunch at about 10:30/11am if that works?
Alternatively I could look at a place to go to for dinner instead if that's what people prefer. Beaufort street is pretty busy at night which makes parking etc. difficult so I'd look elsewhere like Hunter & Barrel in Whitfords - http://hunterandbarrel.com/
Discuss.
  • Like 1
Discuss.
Either is fine for me, will leave it in your capable hands
7 hours ago, ElleAli76 said:
Yup my darling , I’ve blocked the date just for you! Peter , dean , Trev , Justin Keiran they are coming too - just need to find a good place
I work on the 16th, Christmas in Retail. I can only make it after 6pm.
  • Like 1
Hey @z00key here is the option list for R34, i reckon if you know anyone who can read Japanese you could get the part number for the Momo wheel:
http://www.nissan.co.jp/OPTIONAL-PARTS/CAMPAIGN/MOMO/ichiran.html
  • Like 1
google translate seems to have done a good job -
https://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.nissan.co.jp/OPTIONAL-PARTS/CAMPAIGN/MOMO/ichiran.html&prev=search
  • Thanks 1
1 hour ago, ElleAli76 said:
Have you guys started the long hours ?
I believe they start to take shape next week.
It's been so busy, last weekend felt like boxing day.
Edited by Manne
Discuss.
You know we leave the big decisions up to you
  • Like 2
Hey [mention=135083]z00key[/mention] here is the option list for R34, i reckon if you know anyone who can read Japanese you could get the part number for the Momo wheel:
Goo luck finding someone who knows Japanese [emoji41]
  • Like 2
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
