  • Replies 43
it looks much nicer without the wing. Sell it to a kid with an excel for stupid amounts of money and buy yourself some suspension parts to finish that low flying stealth bomber look.
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929401
I took mine off a while back off Shonen and i have the Full Cwest kit as well and its black. So your car would look similiar 2 mine. I think it looks much better without it. All other 34s ive seen have those aluminium GT wings which i sort of dont like.
I think it gives the car a much more refined and sleeker look.
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929746
looks mad without the wing, but you already have the wing on.. so now you have holes in the boot :P
haha yeah dats one of the reasons why i dont wanna leave the wing off....
dont wanna drive around with rubber gromets on the boot.....which seems to be the fashion these days !! :)
with all other aspects of the car I didnt care what others thought cause just wanted what i liked....but i seriously cant decide between the two right now..
so keep it coming people...... :P
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929773
It's just a dumb internet saying :)
I reckon it looks SWEET without the wing... Makes the car look extremely classy and sleek. My vote is to ditch the wing, get the holes welded up and repaint the bootlid :P :P :)
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929788
hmm...sooo tempting....ill see how much i can ditch the wing off for !! hehe
and how much it is to patch the boot up.....
also this is a bit off topic..but i didnt wanna start another thread for it...
is it illegal to have no front number plate ??
cause i took mine off to get better brackets made up....the rattling was starting to piss me off......
but i have to say it looks SOOO much better with no front plate........:P
i heard the front of your car cant be photographed by speed cameras etc...
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929809
1. Looks better without the wing
2. AFIAK it's only legal NOT to have a front number plate if the car is manufactured without anywhere to mount it. I could be wrong but I've seen a fair few Ferrari's without them. Your car does have a mount for the plate so you'll get pinned for not having one
https://www.sau.com.au/forums/topic/45671-wing-or-no-wing/#findComment-929817
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
