Tomorrow is the last day to put your name forward - we need two (2) more people in order to get discounts. If you are interested let me know!
Ok guys we have reached the end date of the group buy. As we only have 3 confirmed interest I dont believe there will be any discounts but I will contact Alpha Omega and see if they are willing to discount anyway. Will keep you posted.
Alpha Omega have offered to extend the group buy until next Tuesday at which time they will review the numbers.
So if anyone else is interested, please speak up by 6PM Tuesday 9th.
  • Like 1
Ok guys, I received no further interest over the weekend so have emailed Alpha Omega to see if they are willing to offer any deal to the 3 confirmed interest.
Will let you know when I hear back.
  • Like 1
Ok guys, I have heard back from Alpha Omega and after receiving a fourth person interested (via PM) they have agreed to offer a discount to these buyers. They are currently setting up the discount coupon for these people and once I have been notified of it I will contact the interested parties via PM with the coupon details.
Awesome stuff Timmy. Thanks.
Will they extend the discount for discs to suit?
I have sent them an email to see if there is any possibility on rotors if also bought at the same time :)
Ok all, for anyone else interested in the discount on the adaptor kit, Alpha Omega has asked me to give out the coupon code!
To receive the discount, all you need to do is use the coupon code 'sau-gb' on the online shopping cart on the Alpha Omega website.
If you use it, give me a heads up and I'll be able to follow up your order for you. The coupon code will only be valid for a limited time as it has been created for this group buy only.
Warning: Coupon is either invalid, expired or reached it's usage limit!
You snooze; you lose
Lol. I will get in touch with then and see if they will fix it up again. Might not be until Monday though.
Cheers. Maybe I snoozed too late..
Alpha Omega have increased the coupon code for a couple of days to allow others to get their purchase made.
Ok guys, there have been four people jump on the group buy and Alpha Omega is leaving the coupon code valid until the 30th as an EOFY discount. The discount will not be offered after this date so if you are interested in getting this kit jump on it whilst you can save yourself some money!
Cheers to everyone that has already jumped on board :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
