  • 6 months later...
Hi all,
I have recently purchased this brake adaptor kit for my R34 GTT, and after learning of my involvement on Skylines Australia, Alpha Omega Racing has offered a discount saving to all SAU members.
Company:
Alpha Omega Racing
www.alphaomegaracing.com
Product:
Evo 350mm Brembo Brake Adaptor Kit. The adaptors are 100% CNC machined billet alloy, grade 7075, which is super lightweight and high strength. There is also a 'Stealth Edition' kit available, where the adaptors are anodised black.
Purpose:
The kit allows you to fit Brembo calipers from an Evo 5-9 (all the same) with Evo X rotors (350mm, much larger than the 320mm used on previous Evo's) to your R32/R33/R34/S13 (5 stud)/S14/S15/Z32/Z33. The reason for not using the Evo X caliper is because they have larger 'legs' which would require the adaptor to be smaller/weaker. The Brembo calipers on the Evo's have a slightly larger pad area than the GTR Brembo's, as well as larger pistons, and can often be bought significantly cheaper too.
What's included:
- Pair of CNC machined 7075 billet alloy caliper adaptors
- High tensile bolts and washers
- Installation instructions (with pictures)
What you need to get - B.Y.O. or supplied by Alpha Omega Racing:
- Mitsubishi Evo 5/6/7/8/9 Brembo front calipers (including pads/pins/shims/clips/banjo bolts)
- Mitsubishi Evo X front rotors (350x32mm)
- Custom brake lines
Alpha Omega Racing can supply all of the above, but you are also able to purchase the parts elsewhere if you wish. I personally sourced the parts elsewhere as I decided to go for 2 piece Attkd rotors and had a local business make my brake lines as I use them regularly for other custom lines. Some people may find it more convenient to purchase all parts for the conversion from Alpha Omega Racing and the listed prices are as follows;
- Evo 5/6/7/8/9 Brembo front calipers (used) - $850
- RDA Evo X 350x32mm slotted rotors - $290
- Goodridge custom brake lines - $240
Alpha Omega Racing can also offer services to rebuild your used calipers, powder coat them, or even install the whole kit.
Wheel clearance:
Minimum of 17" race style wheels with good clearance are required.
Brake Master Cylinder:
You are able to retain your factory brake master cylinder, however it is recommended to upgrade to a brake master cylinder with a piston size of 17/16" (such as a BM57).
Price:
The RRP for the adaptor kit is $370 plus postage, or $385 for the 'Stealth Edition' adaptor kit plus postage. The group buy discount that is being offered is;
- 5-11 people = Normal kit for $340ea, or 'Stealth Edition' kit for $355ea, (save $30) plus postage
- 12-19 people = Normal kit for $310ea, or 'Stealth Edition' kit for $325ea, (save $60) plus postage
- 20+ people = As above, with free postage - including tracking number/signature on delivery/insurance (total saving of approximately $90-110)
Group Buy Condition:
The group buy will run for a two (2) week period, finishing at close of business on 4th June 2015. Anybody interested in purchasing the kit as part of the group buy should notify my by the cut off date and I will add them to the 'buyer list'. At the conclusion of the group buy period I will tally the number of buyers and contact Alpha Omega with the total numbers. A discount coupon will be provided to each buyer allowing them to get the appropriate discount.
Prior to the cut off date all communication will be with me either via this thread or via PM. At the conclusion of the group buy, once you have been provided with the discount code, all communication will be between the buyer and Alpha Omega. All shipping and payment details will be between the buyer and Alpha Omega only. Any warranty on the product(s) will be provided by Alpha Omega.
Pictures:
Adaptor kit
Nissan Silvia S15 with Enkei NT03 wheels 17x9 +15
Nissan Skyline R32 GTR with LM-GT4 18x9.5 +12
If you have any questions please don't hesitate to ask.
Cheers,
Tim
First paragraph. Yes it will.
Mines are 19 with offset of 40
so what I need is an evo 6-9 caliper which is designes for a 320 disc and and evo 10 disc which is 350?
Check out the current group buy thread. This is the old one. All relevant information is on the thread including link to Alpha omega website. They sell everything required for you to run the Evo brakes.
Ryan
Alpha Omega Racing Evo 350mm Big Brake Kit Group Buy Round 3 (WTAC rear kit available)
Hey Stranger,
Yes these will fit an R34 GTT but as above not with factory wheels. The new lines will need to be made to the appropriate length and have the correct fittings either end.
As Ryan has posted above, there is a new group buy for these kits which also includes two versions of the rear kit so feel free to jump in there for more info and post any further questions :)
Tim
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
    • Genuine is best. I have to replace my SIL's Audi A3 DRL module because the $20 alibaba special one has faded within a month... Sigh...
