Hey How U Doin
I Have Custom Yellow N Black Plates
I Wouldnt Mine Sellin 4 A Good Offer
Pm Me If Ne1s Interested
If Not Just Keepem On D Car
Very Good Number Plate
Ciao
https://www.sau.com.au/forums/topic/45691-for-sale-number-plates-mentle/
wel bro u give me a offer wat u would pey 4 those mad plates
wat dey r worth
were u from man
Dude - forum rules stipulate that if you want to sell something you have to name a price. The place isn't E-Bay, so we're not here to auction. :P
omg lol
al i am askin is a price is dat so hard
i can say ne price but if no1s satisfactory about dat price how am i gona sellem
so i sel em at a resonable price n c wat dey offer n work off dat omg
rules
lol
well lookin 4 5gs or more or less
i hav no idea
just want som offers
didnt want ne1 biddin but if more den 1 person likes d plate
obvuilsy i am gona go 4 d highest bidder
Decoded for human beings:
BTW, you're funny.
You wanted to buy the plate, and you don't even know what the word means
How old are you?
hehe
edit: I'm sorry, I can't understand or translate the post above that... You guys are on your own.
