Parts for Sale
Located In Ballarat VIC
Will post most parts at Buyers expense
Open to offers
****RB30 Parts****
R31 Auto Gearbox Computer (Located under passenger seat)
-A64-000 J29 $5
-A64-000 J41 x2 $5
Charcoal Canister $20
Power steering Res $20
O2 Sensor x2 $20 each
Idle Air adjust with FICD $20
Pressure Reg – Solenoid Valve $20
Auto Throttle Position Sensor $5
Air Reg x2 $10 each
Factory Water inlet and out block fittings (Rad hoses connect to) $5 each
CAS(Crank Angle Sensor) x2 $10 each
Coils x4 $10 each
Pressure Reg $10
Throttle body x2 1Missing the Throttle cable connector $10 each
Dizzy x2 $20 Each
Throttle cable holder Block bracket $5
Starter Motor x2 $25 each
Alternator $25
Fuel Pump out of Cradle $20
****Outside Parts****
Chrome Door Handles – All Except Drivers Side $40
Black Door Handle – Front Passenger side $10
Bonnet Hinges Both Left and right $5 each
Fuel Cap $5
S3 Headlight Drivers Side $25
S3 Headlight Passenger side x3 $25 each
Front Bar Indicators – Both sides $10
Chrome Strips that go above the top of the doors – both sides $30
Side Indicators – Both sides $10
Wagon Drivers Side Tail light $10
Wagon Passenger Side Tail light – Small Crack $5
S3 Filler bar x2 $10 each
S2 Filler Bar $10
S2 Passenger Gaurd $20
S3 Passenger and Drivers Side Gaurds $20 each
S3 Front Bar $50
S3 Rear Bar $50
Stock sway bar $10
****Interior Parts****
Ash tray - $5
6 Gauge Cluster x2 $30 each
Pintara cluster (Clock where the rev gauge is) $10
Random Brown interior – Too much to list – Let me know what you after
Random grey dash buttons - Let me know what you after
Grey dash - $20
Brown Dash insert S3 TI (The whole thing the dash sits in) $50
Indicator/Headlight stork x3 $20 each
Wiper stork 1x Adjuster $20 x1 Non Adjuster $10
https://www.sau.com.au/forums/topic/456919-vic-r31-skyline-rb30-parts/
  • 2 months later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
