True...
Op should run 6 inch piping for efficiency.
Obvious sarcasm aside, there is a point (size) where it won't help anymore.
Put a pressure gauge at the outlet of the turbo and one on the plenum, the differential pressure is the pressure drop through the pipe work. Then do it again with the upgrade.
So it wouldnt be the intercooler giving the pressure drop at all?
Yes of course.
Put simply, the least number of bends, shortest length and optimized pipe diameter will be best.
If your turbocharger is compressing the air to 30psi (example) you don't want it to be loosing 5-10psi through pipe work to get it into the cylinder head.
Can't help you with the decision of what plenum to run, but when I fitted my RB26/30 with a Greddy plenum I struck the usual/know problem of the clutch master hitting it.
I got a race car CNC guy to whip me up a spacer to allow me to run a S15 turbo, and have sold quite a few of these to forum members, let me know if you want one
Yes of course.
You seriously think you will lose 10psi through 80mm pipework at this power? No chance.
Some people just want it to look like they have a 2000hp drag car, and this I can totally understand. I just prefer finding out if the stock gear can get the job done before blowing 1000's on overnight parts from Japan, and I am confident it will in this situation.
The same can't be said about exhausts, these need to be as you mentioned, least amount of bends, largest free flowing pipes you can fit. Same with intakes really if you don't have to worry about defects.
  • Like 1
It is just an example, get your mate to put a couple of pressure gauges at the turbo outlet and at the plenum on his 600kW RB with stock pipe work and lets find out :)
Yep, some people like the look, others (like me) would prefer to look for every efficiency they can especially if they are building a turbo system with all custom piping anyway.
Fair enough. I have designed and fabricated pipework on many high horsepower builds, and there are a lot of good reasons to keep the airspeed up. If you want to slow it down as much as possible, who am I to judge.
Just letting OP know the GTR runs one of the best intercooler pipe setups I have seen on a stock car, and it's capable of 600+kw in my opinion, as long as high boost is involved.
As for pressure gauges, it isn't telling you much about the pipework, only how well the intercooler flows and if it's cooling the charge nicely. Pressure readings mean nothing without temperature drop.
I agree it is capable of 600kW of flow... but that's about it from your comments.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
