So i've been having having problems with the car going into limp mode intermittently for a couple of months, some days its really bad and sometimes it wont do it for a week at a time.
My mrs drives it mainly, -taking kids to school etc and its really starting to shit her, and thus it impacts on me.
Since it started happening i've swapped out the pedal tps, the throttle body, (both with known working ones) put a new battery in and wiggled and unplugged shit etc, dit the pedal poition and throttle body relearn stuff, but still get the same problem.
I've searched a lot and it seems to be a common problem but had anyone found a definitive fix?
Oh yeah I've also cleared the drain hole under the battery and dried out all the stuff, (fuse box etc around there)
-Rod
https://www.sau.com.au/forums/topic/457051-m35-stagea-p0121-throttle-problem/
So you have a TPS fault, something is wrong with the tps signal back to the ecu. There are two tps signals and they are both monitored/compared by the ecu constantly and anything that may throw the voltages out, even slightly will trigger the limp mode.
Do you have anything else hanging off the TPS wires? Such as a cruise control, piggyback ecu or something else aftermarket?
Yeah I punched out the drain tube.
However the error occurred 3 times again today.
After being good for a few days. I don't know what to do now!
I've got a whole other car for parts so I might just keep swapping things. Starting with that whole fuse box, and maybe the ecu.
My mrs said it seems to rev up more than it should just before it throws the error. And it's always after stopping at an intersection or something and when she gets back on the accelerator it does it.
It sounds like a problem with the throttle potentiometer going high or low just off closed but it's been swapped with one from the other car that was fine
Plenty of times, either the throttle resistor on the back of the pedal, or the throttle itself is likely the issue, unless you have a wiring fault between them and the ecu.
What codes are the ecu throwing? Is it only the P0121? That seems to relate to the pedal sensor.
When the throttle goes into limp mode it almost disables the throttle. It will sit on 1200 revs, enough to drive out of problems and get off the road. You can actually get more throttle out of it if you push the pedal all the way to the floor, but it is quite dangerous, especially as it happens randomly.
Yeah that's the only code, and having tried the pedal assembly and throttle body from the other car that never had a problem I'm suspecting a wiring issue, corrosion, dry joint, or ecu problem, I'll swap the ecu and fuse box out over the weekend and pray that fixes it. It was strange that it worked flawlessly for 3 days after changing the relay so maybe there is a wiring problem in the fuse box.
What locally sold car has the same throttle pot? I vaguely remember reading it was a Maxima but can't find it again...
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
