Hi guys, Matty here.
Been reading for a few months but only joined recently.
Unfortunately had my stagea s2 rs4 manual written off and am looking to buy another stag asap.
Love the car to bits and I will be parting it in the next month or so.
ATM I can only find series 1 stageas for sale, and the one I am looking at is pretty clean. Wondering whether it's worth doing a manual/engine changeover to the neo/manual from my series 2?
Please let me know what you think and hope to be cruising again soon.
https://www.sau.com.au/forums/topic/457064-gday-mates-wtb-stagea/
Hey Ben.
Only reason I had considered a manual conversion was the one I'm looking at has the r34 front conversion done and it's a pretty decent price. Automatics just hurt my heart haha.
I know there is probably a lot of work with the conversion but I have the bits available, can you elaborate a bit more?
like most models of cars, it's not just the engine loom that will be different. If you're willing to strip both cars; carpet, dash, everything, yes it can be done quite quickly. You will still need to do some cutting of the loom, whether that may be engine engine bay dash body etc. The other way is to start cutting, but most people do this who have done it before or have wiring diagrams.
I can tell you first hand, once you have found one problem another will pop up.
Could always sell the neo for 1-2g and put your manual into the 34 fronted s1. Then later on wire in a stand alone to tune.
Yeah I'd assume as much.
Did he post anything about it on here?
I have a power fc ready to go and a few other bits and a perfectly good neo hence why the question about the change.
Is the series 2 manual gearbox compatible with non neo rb25det?
There just doesn't seem to be any series 2 manuals that haven't hit 200xxx clicks.
Cheers for the heads up though mate.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
