Hi all, reasonably new to the forum but have a question about my suspension. I purchased the GTR which already had Bilstien coilovers installed. The shock has a sticker with the following code F4-B46-2108-HO.
The car felt very firm even with standard wheels, now that I have put 18s and reduced the height a little (the shock has guiders so you adjust the height up and down), I think the ride seems too stiff.
Never owned a GTR before so not sure if the ride is just normal for a GTR or not (but me thinks it's not right).
Anyone got any advice on these coil overs or where I could get some good advice from? Thanks!
https://www.sau.com.au/forums/topic/457292-suspension-question-r33-gtr/
I presume with these ones that if you lower it you are compressing the spring, correct?
If so, the more you compress the spring the firmer/shitter your ride will become.
If you dont like them, and they are not damper adjustable then maybe its time to invest in some quality suspension, usually stay away from jap coilovers as they love to be stiff.
As for stiffness of ride of a R33 GTR, my car was as stiff as a gokart on standard suspension.
Thanks, yes that's correct however it's is far from being low.
Happy to invest in coilovers and like you say will stay away from Japanese but given my existing ones aren't Japanese and not slammed to its lowest setting I guess I need to figure out if a change will actually help or am I better off maybe checking and changing springs with different spring rates..
The stiffness of the ride is not a function of those shock absorbers - it is down to one of two things:
1. You are running a stiff spring - which begs the question what springs do you have.
2. The car is low and you have run out of travel on the shock absorber or springs.
Before you do anything else stick your head under the car and have a look what springs there are. Take some pictures if you cant figure it out.
That model code is for a Bilstein B6, which is their mid-range (really nice) damper series.
The spring perches on those Bilsteins are not natively adjustable for height unless you're talking about dismantling them, relocating the circlip to a higher (or lower) groove, then putting them back together.
If there are adjustable height spring perches on them then they have been modified. One of the main guys who has been doing this over the years is a guy from here, SydneyKid. Do a search or two looking for posts from him and others about his gear.
These dampers may or may not have had decent adjustable perches put on them. The crudest sort just allows them to be screwed up and down, compressing the spring more or less. This alters the pre-load on the spring at the same time as adjusting the height, which can lead to nastiness, although it's not usually too big a problem as long as the height change is not too great.
If they do only have nasty-style height adjustment on them, you could conceivably get them further modified, by SydneyKid for example, to give proper adjustability for a LOT LESS than $2k.
Whether the above makes sense also depends on what springs are on there, as has already been mentioned. Photos, as mentioned, a good idea. Also get a pair of verniers onto them to measure the wire diameter, and try to count how many full coils they have. With that info an the colour (from the photos if nothing else) we might have a chance of working out whose springs they are and therefore what their specs may be. it's not possible to work out the specs completely without pulling the spring all the way out of the car.
If it turns out that the springs are stupidly stiff, then new ones are only going to set you back ~$500.
On the topic of spending $2k on new "suspension" or <$2k on modifying the existing Billies, I would far rather keep the Bilsteins that drive around on any coilovers that cost only ~$2k. You need to spend a LOT more than $2k on coilovers before the quality of the dampers in the coilovers starts to get anywhere near that of the Bilsteins.
Now to some specific advice. Wind the suspension height back to where it was. Drive it. Still too stiff? Welcome to the world of really low profile tyres. Note that it's not the suspensions fault (at that point).
  • Like 1
djr81 - a little dark for photos now but will try tomorrow. The springs are black in colour.
GTSboy - agree completely. My research to indicated that the damper is a good quality B6 damper and why I think it might be worth investigating spring rates. I adjusted the height by relocating the circlips as you mentioned. Even at its original position and on stock wheels the car (to me) felt very stiff and crashy which is why I think the spring rates maybe the issue.
I will take some photos of the springs tomorrow and post up. By the way how can I contact Sydneykid?
Black springs way well be Eibach which are usually pretty sensible. When you are under there try and find some writing on the spring itself. Usually a part number.
Also, if possible try and see how much clearance there is between the top of the shock absorber and the underside of the bump stop (You may not be able to as you will probably have dust boots on them).
Lastly measure from the centre of the wheel to the wheel arch and let us know.
The spring perches if they are the usual type just jack the car up and down and dont adjust the spring compression.
My money is on too low a ride height.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
