Just a tip: even though illegal tint looks cool it is illegal for a reason.
I got graphite 35 which is prety light considering some of the tints out there but u can see through it clearly at night. Guy on sheilds crs in Myaree did mine and it not a bad job and comes with lifetime guarntee. Cost me 220 all up.
I think F1 is the darkest legal available and u can only get that from solace:)
Use DMS Energy on Hutton St is Ossy Park -they are the only authorised 3M automative film fitters in WA apparently and they do an excellent job.
They have a new film called carbon black that look INSANELY dark on the outside, but is still legal and clarity is excellent from the inside.
If you are with the RAC mention it, you get a discount.
i have f1 tint from solace on my mr2 (as seen in the avatar),
it's pretty dark but still good at night. Highly recommend it!
there was a story about a guy in Adelaide who had illegal tint, it was dark and he didn't see a cyclist, cleaned him up and ended up having to foot ALL the compensation bill because of the illegal tint voiding his 3rd party. :eek:
don't know how true it is but i have a major gripe against dark tint anyway, you can't see much at all through the car at intersections when you need to see on comming traffic etc. :cool:
i think i will be going legal, to each their own but for me i think being able to see what is happening around me at night is very important, especially when you do country driving and there are no road lights to help you see whats at 90 degrees. Also having my insurance voided in a crash would be very nasty, cheers for all the replys
yeah mine isnt that dark so i dun think i would get into trouble...i drive with the windows down anyways...
my main concern however is that people might break into the car thinking that there is stuff to steal but in the end all i have is a factory head unit.
what sux is that if those kind of people will just smash your window whether there is something inside or for the off chance of 20cents being left in the ash tray, even if they could see in and see nothing they would probably run a screw driver down the side of your car anyway...their scum...................i hate them all:mad:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
