1997 R33 GT-R FOR SALE
Engine:
R33 cylinder head, R34 standard bottom end. Purchased from Japan with engine number to prove block is from R34 GT-R.
Nismo 1.2mm metal head gasket
Tomei 1.5mm oil restrictor
Tomei sump baffle with trap doors
Gates Racing timing belt
Nissan OEM RB26 water pump
Nissan OEM Long Life Coolant
NGK BCPR7ES every 5,000km
Racepace Motorsport adjustable cam gears
K&N high flow panel filter in stock airbox
Garrett 2859-9 (HKS GT-SS equiv) with brand new gaskets, washers and adjustable actuators
Racepace boost controller
Just Jap oil catch tank with washer bottle
Nismo RB26 Airflow metres
Nismo RB26 276lph fuel pump
XSpurt 1000cc injectors
Apexi Power FC with hand controller
Splitfire RB26 coil packs
Mine's 70x2mm to 80mm front pipe
3" test pipe
Tomei 3.5" Ti Expreme catback
There may be more that I have missed, but the whole engine setup is quite track safe with the addition of an oil cooler. Castrol Edge 10w60 is used every 5,000km and oil temps stay below 100 degrees on spirited driving.
The beauty of this setup is that it can easily be reverted back to factory standard as everything was a bolt on affair and I have ALL the standard engine parts AND a whole bunch of spares (plenum, fuel rail, sump, CAS etc); which will be included in the sale. Also included in the sale will be a complete dump back standard R33 GT-R exhaust system and standard R33 GT-R V Spec suspension.
The car was tuned in August at Chequered Tuning on United E85. Final power figure was 364rwkw @ 6,500rpm and just shy of 600Nm @ 4,000rpm. Reaches full boost of 21psi by 4000rpm.
Drivetrain:
Nismo Super Coppermix twin plate clutch
Redline MT90 transmission fluid
Nissan OEM D-Matic fluid for ATTESSA system
Motul Gear 300 LSD fluid
Brakes:
Standard R33 GT-R Brembos with Ferrodo DS2500 pads front and rear
ADR approved braided brake lines
Motul RBF600 brake fluid
Suspension:
BC BR coilovers OTS spring rates (8kg/mm front, 6kg/mm rear)
Adjustable front upper camber arms
Cusco adjustable castor rods
Wheels and tyres
20mm bolt on, hubcentric spacers
Standard R33 GT-R 17"x9" +30 wheels with 245/45/17 Dunlop Z1 Star Spec tyres.
Interior:
Nardi 330mm deep corn steering wheel with Daikei hub specifically for R33 GT-R (no ABS lights)
Nismo GT duracon shift knob
Exterior:
Just Jap carbon fibre rear wing blade
Nismo GT-R spoiler end caps
N1 bonnet lip
Once again, I may have missed a few things but this gives you a good idea of what the car presents. The body has a few imperfections as the car is actually driven and currently sits on approximately 127,xxxkm. I can't imagine it being a major turn off to potential buyers though.
The car is for sale at a price of $25,000 ONO.
RWC can be provided upon negotiation with the buyer.
I have been as thorough as possible in specifying what I have to offer and would appreciate nobody making ridiculous offers. I am not here to entertain joy riders and a deposit would be required prior to test driving the vehicle.
Kindest regards
Michael
  • Like 2
https://www.sau.com.au/forums/topic/457556-vic-97-r33-gtr-9-e85-365rwkw/
  • 1 month later...
  • 2 months later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
