Hey all,
Been building up my 89 R32 GTR, running out of room in the garage. All parts came off a 89 R32 GTR, 120xxx km in working order.
All parts located in Hurstville, NSW, local buyers only, not too keen on shipping due to weight and size of some items
For any questions or quires, do not hesitate to PM. Cheers
R32 GTR RB26 stock turbos - minimal shaft play. stock boost $250
R32 GTR RB26 stock cam gears - $50
R32 GTR RB26 stock rubber FMIC piping - $50
R32 GTR RB26 stock FMIC intercooler - $100
R32 GTR RB26 stock radiator - $100
R32 GTR stock boot lid - boot has rust in the right upper corner, wing would need re-fibreglassed/painted - $20
R32 GTR carbon fibre intercooler insert - has damage in the lower corners, only selling due to unable to fit with 100mm FMIC -$200
post-71835-0-79860300-1434875334_thumb.jpg post-71835-0-27710300-1434875347_thumb.jpg post-71835-0-09875500-1434875360_thumb.jpg
https://www.sau.com.au/forums/topic/457669-fs-nsw-r32-gtr-parts/
More parts added
R32 GTR front 324mm UAS adaptor kit, used R32 GTR calipers used, used R33 GTR front rotors, HC800 project mu pads (used for less then 100kms) before upgrading to bigger brake setup - $600
post-71835-0-33067400-1434974827_thumb.jpg post-71835-0-88057000-1434974802_thumb.jpg
R32 GTR HKS silent hi power exhaust (front pipe not included) -$200
R32 GTR 3.5 inch RSR exhaust, stainless steel -$100
post-71835-0-77384900-1434974742_thumb.jpg post-71835-0-23461800-1434974775_thumb.jpg
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
