Gday Gents
First time creating a build thread here and very green with the Nissan product
A bit of history and my back ground in cars has weighed heavily with Fords I own a FPV F6 Typhoon since 2008 this car didn't stay stock for long.
It has gone through a number of transitions over its life to be a very reliable tuff street car 730rwhp or 540rwkw
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/
I then purchased a R33 GTST as a rolling shell off a friend at work This car came with everything bar a engine
me and my girlfriend at the time sourced a RB25 motor and began the build
We ended up running a T04 turbo and it made a mild 460rwhp on United P100
We had a heap of fun with this car at power cruise events and cruising but the bug had bitten hard I wanted more power but the car had massive traction issues as it was
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567886
After a bit of thought I realized that a GTST wouldn't cut it. I already had a big hp RWD car
It was time to find a GTR
Introducing the new project
1995 R33 GTR Vspec purchased as a roller off a bloke off the forums Matt Haines
Edited by frostyboy
  • Like 1
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567893
So went a bit crazy at the start. Bought a RB30 block and crank, CP pistons, spool rods ect but really forgot what I wanted out of the build
High reving twin turbo the 2.6L engine had that ability and I was about to throw a 3L at it I really want to do a 26/30 build however now was not the time first I needed to get the car on the road and experience what the RB26 could do
I picked up a low km rb26 engine which was running only 6 months before. It had some good bits in it
Poncams, eagle rods and CP pistons Picked up some -5 twin turbos and a vipec ECU
Planned on dropping it in and getting it licensed. But after a few interesting conversations some invaluable information was given to me which I'm glad I followed through with I went ahead and pulled the sump off and check all the bearings
Well I'm glad I did
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567987
After removing the intake plenum and throttle bodies The cylinder head ports were also very wet with oil and on closer inspection they didn't have brass valve inserts
The pistons on number 2 and 6 had massive pitting on the tops from destination
The bearings were made of a really soft material and chunks were missing out of them they were a very soft material so soft the chunks that have come away had not damaged the crank
Edited by frostyboy
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7567995
So now a full engine build is a go the list of parts as follows
Ross Pistons
Eagle Rods
ACL race main bearings and big end bearings
ARP head studs and main studs
Tomei head gasket
HKS step 1 camshafts
Ported head with bronze/brass guides
N1 oil pump with billet oil pump gears
N1 water pump
Tomie sump baffle with trap doors
I purchased a Greddy plenum awhile back so throwing that on as well
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7568241
Covers look great :)
Car is clean man, hope all goes well with the new engine!
Thanks man
The car is very clean. The engine bay has been repainted and cleared about 2 years ago so it's something I don't need to worry about
I have found a few bits and pieces that aren't right for this year car though
I found out the car has a R32 gearbox in it
It has a R32 ignition wiring harness in it so the ignitor is separate from the coil packs
It had various after market gauges and timers in it I have stripped them all out and am starting again
Doe anyone knows if these HKS knock boxe and timer are any good
Either way I pulled them out I think they may be missing components
https://www.sau.com.au/forums/topic/458241-r33-gtr-vspec/#findComment-7569018
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
