Hey, recently purchased a 25/30 motor for my r34, runs r34 neo head. Been doing some research on the rb30 crank compared to the 25 crank and apparently the 30 crank due the it's design has bad harmonics that cause it to have revving issues. I found some info stating that rb30's have a tendency to break oil pumps over 7500rpm. Now I don't intend to spend buckets of money on my car, so I would prefer to avoid buying a good aftermarket counter weighted crank, however I was wondering if anyone has used the fluid style damper and if it helps eliminate some of the 30 cranks harmonic issues. Thanks
I haven't heard about any RB30 crank problems but if you want to rev an RB30 way beyond its designed speed its long stroke starts to make itself felt. You need to make sure the whole thing is well balanced from clutch to damper. What revs do you plan to use anyway? If you are going way over 7,500 most people would get a suitable ATI damper or suchlike. Most cheap builds just don't rev the hell out of them and still make good power.
  • Like 1
Its there, its real on RB30's its been seen and documented for a long time.
However its at certain RPM's in varying degrees, for example you may have one at 7640, a smaller one at 7980 and maybe a huge one at 8140 etc.
The point being is your not sitting at that exact RPM, you rev through it, doing so its just a slight harmless bleep while transitioning through.
Hold it at exactly the right harmonic point for long enough and expect the engine to be tearing itself to sherds....your just passing through it which does not leave enough time for anything to happen.
I have discussed this between quite a few big HP RB30 drag engine builders (1000Hp+) and none have had issues with it however all have agreed if you sit there long enough at that sweet spot it wouldn't be a good thing.
Who holds a engine at exactly 1 high RPM? (and it happens to be that right harmonic spot)
While on the subject, many different engines have a inherent harmonic issues due to design, i remember Cosworth having one with their Turbo F1 design and simply giving up on the engine and taking it back to the drawing board.
Just thought id throw this in, below is the video of the Cosworth engine harmonics failure, dis-assembly and prognosis that i mentioned.
The 15 min mark is when they held it at the harmonic sweet spot on the dyno, 16min mark it failed, from there they tore it down and at the 25 min mark they say "incurable vibration at the crankshaft"
No amount of balancing will help it once the engine design has a inherit harmonics issue......
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
