I know wheels have been covered before but I wanna know what the lowest offset 19" wheel someone is running on their M35 or PM35 stag. I'm looking at a 19x11 +10 rear and 19x10 +23 front, I know the fronts will fit but unsure of the rears? The car is on air and I know ill have to run a fair amount of camber.
https://www.sau.com.au/forums/topic/458472-stagea-big-wheels/
Camber is not a solution for wheels that don't fit. The wrong camber will upset your handling and chew out tyres. Modifying the guards is the way to go. Or getting wheels that fit.
BTW the smallest tyres you should run on 11in rims is 275 - better is 285 or 295 (max 305)
  • Like 1
The stance life is obviously not your life. I understand alot of camber will wear my tires faster but I'm wanting to know what the lowest offset someone is running on their car. I need to clear big brakes and want a lot of dish.
Yeah you aren't going to make too many friends on here or (by the looks of it) get any decent responses.
http://www.sau.com.au/forums/topic/92233-stagea-wheel-dimensions/page-34?hl=%2Bm35+%2Bwheels#entry7295817
search function helps too but i'm not sure you will find much info on what looks good stance life wise
Good lock
Stance life is not the popular life on here that's for sure.
So yu have big brakes for looks also?
I understand alot of people hate stanced cars, im not one of those blokes running double digit camber and scrapping on leafs. The big brakes are an upgrade over the stock shitty ones, I thought I may as well go big. 356mm fronts and 330mm rears
  • Like 1
Yep I'm one of those who prefers function to stance but hey its your car - go for it. But I doubt you'll fit 19 x 11 with 10P without modifying the guards and perhaps not even then if its fouling on the inside..
Try this site:
http://www.willtheyfit.com/index.php?width=215&aspect=45&diameter=17&wheelwidth=7&offset=45&width2=235&aspect2=40&diameter2=18&wheelwidth2=9&offset2=35#content
Try this site:
I've been on that site quite abit but it's hard without having the wheels to test it in person. The guards will definatelly have to be modified, time to test fit some wheels I guess.
Here's a start, more aggressive than the specs you've listed but something to throw in to an offset calculator to compare if nothing else.
http://www.stancenation.com/2013/01/06/stagea-from-across-the-pond/.[/quote
Perfect stagea, im buying very similar wheels. With everything online I'm not sure if people are using spacers, I don't want to.
There is never any need to use spacers if you can afford to buy the right offset. But note that the featured car has had megabucks spent on reshaping not just the guards but the doors
I understand that car is far from stock and no doubt it isnt using spacers, however there's alot of cars that do run them. I think I've found some offsets that I'll be able to work with though. 19x9.5 +10 and 19x 10.5 +15
That M35 above is mine. Yes semi slicks are gone, replaced them with 245/35/20 on the 9.5 fronts and 275/30/20 on the 10.5 rears. Fronts have 25mm spacers to clear the brakes but still fit under the guard without a problem.
My rear tyres have around 3mm clearance to the plastic guard with camber around -1.5 (not sure haven't had an alignment lately). Non axis models don't have the plastic guards so may be different for you.
Depending on tyre size you could possible get a 19x11+10 to fit, but camber would be up a bit.
Also, just curious, which air setup did you get? And is your car RWD or AWD?
  • Like 1
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
