Jesse Streeter in Japan, direct from Nissan, I have ordered a spare FOB and key (separate parts)
Thanks, Wouldn't you mind to share the contact details with me? What info needs to be provided to make sure I get the correct key?
Edited by bennz
inb4 guy stole a v36 and wants a spare key so he can sell it
How can you steal one if you need a key to start ?
My car is jap import and it is common they come with one key (probably the sell the other one to make money). Hence being push start system, I want to have a spare control (dont need the key just the remote) in case I lose the current one.
Dealer charging around $300 for it which is ridiculous. So Want to source it myself and take it to them to program it.
Nope, a lot cheaper from Japan, even after postage to Oz and commission is added on top.
an Adelaide Nissan Dealership Parts quote:
FOB $219.45 AUD
Key $35.15 AUD
Streeter quote:
FOB 6480 yen
Key 1253 yen
+ commission + freight = 11933 yen. = about $131 AUD all up (give or take with exchange rate fluctuations)
www.jessestreeter.com
To be certain you are ordering the correct parts from Nissan in Japan, provide Streeter with your VIN #.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
